AutoCAD Forum
Wrapping text to fit a curved surface in AutoCAD
11 REPLIES 11
Message 1 of 12
4924 Views, 11 Replies
Yes. How do you do that please?
11 REPLIES 11
Message 2 of 12
SOLIDEDIT BODY IMPRINT
Message 3 of 12
Right! Hey! Any answer available to my question?
Message 4 of 12
Patchy
Go to App Store and get it free.
Message 5 of 12
john.vellek
Hi @Anonymous,
I like to use the PROJECTGEOMETRY feature in AutoCAD.
I made a quick video for you on how I suggest using this.
I first created a cylinder object.
Next I created my text, then exploded it with the ExpressTools TXTEXP.
I clean up the outlines of the text.
Then, I use PROJECTGEOMETRY to select the cylinder and then the objects to project.
I hope this helps.
John Vellek
Message 6 of 12
in reply to: john.vellek
Hi John, that was GREAT! AND SIMPLE. Thank you very much.
My intention is to build up an emboss from that. I try it on several ways but did not work to build up a surface from the splines resulted.
Could you help out with that too please?
Message 7 of 12
john.vellek
Hi @Anonymous,
I am always willing to try. Can you attach some files and show me what you are trying to accomplish?
John Vellek
Message 8 of 12
Please find attached my trying outs. Thanks again
Message 9 of 12
john.vellek
Hi @Anonymous,
Similar to my previous technique, you can also use IMPRINT to get the outlines onto the surface.  Embossing has been more of a challenge for me in the past.  I usually presspull my text (or shape) to have some thickness to it. Then I move the 3D text so that it is inserted into the solid of the cylinder in your case. Then I just perform a Subtract.
Does this work or do you need a precise embossed "cavity" depth?
John Vellek
Message 10 of 12
Yes, it goes the to subtract/slice operation which can be also done twice to keep the same high of the text on the curved surface, I was only wondering if it goes all in one go somehow. But I have it like that just fine. Thank you very much for helping out.
Message 11 of 12
SEANT61
in reply to: Patchy
Thanks for the mention, Patchy.  As additional support of the recommendation here's a screen cast illustrating the use of the uvVectorMapping app.
Depending on the degree of wrap, the process demonstrated can maintain letter proportions better than direct IMPRINT of extruded geometry
May your cursor always snap to the location intended.
Message 12 of 12
Julio_Soto
in reply to: SEANT61
is the uvVectorMapping app available on the appstore? I couldn't find it.
