Wrapping text to fit a curved surface in AutoCAD
No aplicable
Yes. How do you do that please?
0 Me gusta
Responder
Soluciones aceptadas (2)
5.450 Vistas
11 Respuestas
Respuestas (11)
No aplicable
SOLIDEDIT BODY IMPRINT
0 Me gusta
No aplicable
Right! Hey! Any answer available to my question?
0 Me gusta
Patchy
Go to App Store and get it free.
0 Me gusta
john.vellek
Solución aceptada
Hi @Anonymous,
I like to use the PROJECTGEOMETRY feature in AutoCAD.
I made a quick video for you on how I suggest using this.
I first created a cylinder object.
Next I created my text, then exploded it with the ExpressTools TXTEXP.
I clean up the outlines of the text.
Then, I use PROJECTGEOMETRY to select the cylinder and then the objects to project.
I hope this helps.
John Vellek
No aplicable
Hi John, that was GREAT! AND SIMPLE. Thank you very much.
My intention is to build up an emboss from that. I try it on several ways but did not work to build up a surface from the splines resulted.
Could you help out with that too please?
0 Me gusta
john.vellek
Hi @Anonymous,
I am always willing to try. Can you attach some files and show me what you are trying to accomplish?
John Vellek
0 Me gusta
No aplicable
Please find attached my trying outs. Thanks again
0 Me gusta
john.vellek
Solución aceptada
Hi @Anonymous,
Similar to my previous technique, you can also use IMPRINT to get the outlines onto the surface.  Embossing has been more of a challenge for me in the past.  I usually presspull my text (or shape) to have some thickness to it. Then I move the 3D text so that it is inserted into the solid of the cylinder in your case. Then I just perform a Subtract.
Does this work or do you need a precise embossed "cavity" depth?
John Vellek
No aplicable
Yes, it goes the to subtract/slice operation which can be also done twice to keep the same high of the text on the curved surface, I was only wondering if it goes all in one go somehow. But I have it like that just fine. Thank you very much for helping out.
0 Me gusta
SEANT61
Thanks for the mention, Patchy.  As additional support of the recommendation here's a screen cast illustrating the use of the uvVectorMapping app.
Depending on the degree of wrap, the process demonstrated can maintain letter proportions better than direct IMPRINT of extruded geometry
May your cursor always snap to the location intended.
Julio_Soto
is the uvVectorMapping app available on the appstore? I couldn't find it.
0 Me gusta
