AutoCAD Forum
Viewport lock does not work
7 REPLIES 7
Message 1 of 8
anch2304
1177 Views, 7 Replies
The viewport lock button on the toolbar does not work. Nothing happens when i push the button. Why?
7 REPLIES 7
Message 2 of 8
GeeHaa
in reply to: anch2304
Can you post your drawing?
Message 3 of 8
vinodkl
Hello @anch2304
Can you select the viewport and then right click, choose display locked and select "Yes". Does it lock now?
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 4 of 8
paullimapa
if pspace vport is on a locked layer, then you cannot display lock the vport
Paul Li
IT Specialist
@The Office
Message 5 of 8
anch2304
in reply to: paullimapa
Thank you! That is the problem. The viewport was on a locked layer.
Message 6 of 8
paullimapa
glad to have helped...cheers!!!
Paul Li
IT Specialist
@The Office
Message 7 of 8
Saved me thank you so much!!!!!!
Message 8 of 8
you are welcome...cheers!!!
Paul Li
IT Specialist
@The Office
AutoCAD Inside the Factory
