The viewport lock button on the toolbar does not work. Nothing happens when i push the button. Why?
Solved by anch2304. Go to Solution.
Solved by paullimapa. Go to Solution.
Solved by vinodkl. Go to Solution.
Hello @anch2304
Can you select the viewport and then right click, choose display locked and select "Yes". Does it lock now?
if pspace vport is on a locked layer, then you cannot display lock the vport
glad to have helped...cheers!!!
you are welcome...cheers!!!
