A cube appears on the CAD mouse cursor.
ajy0892
Observer Observer
Message 1 of 8
ajy0892
Observer
Observer
I got a cube like the image below. I want to know how to get rid of it.
shared image.jfif
Replies (7)
Message 2 of 8
imadHabash
If you change CURSORBADGE (System Variable) =1 , any changes?
Also try to check CURSORTYPE (System Variable) = 0 .
BTW.. This is the first time ( as much i remember ) that i see this 3d cube next to CAD cursor!!
Imad Habash
Message 3 of 8
pendean
Community Legend
Community Legend
Is this in ALL of your files, or just this one?
What is unique about this one file? Not one of your, or you are exploring a feature?
Message 4 of 8
ajy0892
Observer
Observer
There is no special change when you change the CURSORBADGE value to 1.
and CURSORTYPE value is 0!
Message 5 of 8
ajy0892
Observer
Observer
It only applies to this file. I'm not sure what's special about this file...
Message 6 of 8
j.palmeL29YX
Can you share this file with us? (post it here please)
Jürgen Palme
Message 7 of 8
pendean
Community Legend
Community Legend
INSERT this file into one of your own problem-free TEMPLATE files, EXPLODE, SAVEAS, give it a name, then explore it. What's different may become very apparent especially if it has content in it.
And keep an eye on the commandline the whole time (make it three-five lines tall): AutoCAD will likely tell you something you did not know as well.
Message 8 of 8
TheCADnoob
That looks like the sub object selection toggle
Each of these options change the appearance of the badge
If you don't see that option it can be turned on here
Also on the ribbon
CADnoob
