Viewbase MD Layer Issue
dcolley_ptfnola
Message 1 of 12
dcolley_ptfnola
I have the MD layers created and linetypes set in my drawing template, but all of a sudden AutoCAD started making additional MD layers with _O at the end of them.  I can merge them into the original layers but have no idea why AutoCAD is creating them.
David Colley
Picardie Timber Frame + Millwork
New Orleans, LA
Replies (11)
Message 2 of 12
imadHabash
honestly , i have NO idea how it's appeared . But you can by PURGE command get rid of them because it's still unused layers .
Imad Habash
Message 3 of 12
dcolley_ptfnola
Thank you.  It is actually used until I merge it to the "non_O" layer.
David Colley
New Orleans, LA
Message 4 of 12
dcolley_ptfnola
This is really frustrating!
David Colley
New Orleans, LA
Message 5 of 12
Alfred.NESWADBA
can you please upload the dwg-file where these layers are created, let us know the exact commands you are using + send us a screenshot of command/dialog _ABOUT so we know which product/version/update you are using.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 6 of 12
dcolley_ptfnola
In model space, I'm selecting geometry and typing vbase.  I'm selecting layout 01.  At that point, my MD_ layer goes from this...
to this...
see attached file.
Thank you.
David Colley
New Orleans, LA
Message 7 of 12
Alfred.NESWADBA
then drawing you attached already has the "_0" layers, so I
  • deleted the viewbase object in the layout
  • purged all layers
  • started again command _VIEWBASE to create a new view in layout 01 from the modelspace content
...even if I start this multiple times I don't get any "_0" layers. If you follow this workflow, do you get again the "_0" layers?
- alfred -
Alfred NESWADBA
Message 8 of 12
dcolley_ptfnola
I did that and i didn't get the _O layers, but now I have all my template layers (including the pre-defined MD_ layers) gone.  That worked, but I lose my template layers and layer properties.
Maybe I'll try to purge them out of my template and recreate them.
David Colley
New Orleans, LA
Message 9 of 12
Alfred.NESWADBA
>> and recreate them
Did your template already contain the "MD_"  layers? If so this could be the source of the issue.
Try to purge all "MD_" layers from your template.
Then create one 3D-Solid, run one time command _VIEWBASE so you get the "MD_" layers created. Change the layer properties for these new layers to your needs. After that delete the viewbase-object from layout as well as the 3D-Solid object from modelspace and make this your new template.
Does that work for you?
- alfred -
Alfred NESWADBA
Message 10 of 12
dcolley_ptfnola
Must have been something in my template .dwt.  I purged out those layers and recreated them.  All seems good for now.  Thanks, @Alfred.NESWADBA .
David Colley
New Orleans, LA
Message 11 of 12
Alfred.NESWADBA
great, good to know all is working well again!
- alfred -
Alfred NESWADBA
Message 12 of 12
dcolley_ptfnola
Thank you sir.  Have a great one.
David Colley
New Orleans, LA
