AutoCAD Forum
Viewbase MD Layer Issue
11 REPLIES 11
Message 1 of 12
dcolley_ptfnola
928 Views, 11 Replies
dcolley_ptfnola
I have the MD layers created and linetypes set in my drawing template, but all of a sudden AutoCAD started making additional MD layers with _O at the end of them.  I can merge them into the original layers but have no idea why AutoCAD is creating them.
David Colley
Picardie Timber Frame + Millwork
New Orleans, LA
David Colley
New Orleans, LA
Labels (2)
11 REPLIES 11
Message 2 of 12
imadHabash
honestly , i have NO idea how it's appeared . But you can by PURGE command get rid of them because it's still unused layers .
Imad Habash
Imad Habash
Message 3 of 12
dcolley_ptfnola
Thank you.  It is actually used until I merge it to the "non_O" layer.
David Colley
New Orleans, LA
David Colley
New Orleans, LA
Message 4 of 12
dcolley_ptfnola
This is really frustrating!
David Colley
New Orleans, LA
David Colley
New Orleans, LA
Message 5 of 12
Alfred.NESWADBA
can you please upload the dwg-file where these layers are created, let us know the exact commands you are using + send us a screenshot of command/dialog _ABOUT so we know which product/version/update you are using.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
- alfred -
Alfred NESWADBA
Message 6 of 12
dcolley_ptfnola
In model space, I'm selecting geometry and typing vbase.  I'm selecting layout 01.  At that point, my MD_ layer goes from this...
to this...
see attached file.
Thank you.
David Colley
New Orleans, LA
to this...
see attached file.
Thank you.
David Colley
New Orleans, LA
Message 7 of 12
Alfred.NESWADBA
then drawing you attached already has the "_0" layers, so I
  • deleted the viewbase object in the layout
  • purged all layers
  • started again command _VIEWBASE to create a new view in layout 01 from the modelspace content
...even if I start this multiple times I don't get any "_0" layers. If you follow this workflow, do you get again the "_0" layers?
- alfred -
Alfred NESWADBA
  • purged all layers
- alfred -
Alfred NESWADBA
Message 8 of 12
dcolley_ptfnola
I did that and i didn't get the _O layers, but now I have all my template layers (including the pre-defined MD_ layers) gone.  That worked, but I lose my template layers and layer properties.
Maybe I'll try to purge them out of my template and recreate them.
David Colley
New Orleans, LA
David Colley
New Orleans, LA
Message 9 of 12
Alfred.NESWADBA
>> and recreate them
Did your template already contain the "MD_"  layers? If so this could be the source of the issue.
Try to purge all "MD_" layers from your template.
Then create one 3D-Solid, run one time command _VIEWBASE so you get the "MD_" layers created. Change the layer properties for these new layers to your needs. After that delete the viewbase-object from layout as well as the 3D-Solid object from modelspace and make this your new template.
Does that work for you?
- alfred -
Alfred NESWADBA
>> and recreate them
- alfred -
Alfred NESWADBA
Message 10 of 12
dcolley_ptfnola
Must have been something in my template .dwt.  I purged out those layers and recreated them.  All seems good for now.  Thanks, @Alfred.NESWADBA .
David Colley
New Orleans, LA
David Colley
New Orleans, LA
Message 11 of 12
Alfred.NESWADBA
great, good to know all is working well again!
- alfred -
Alfred NESWADBA
- alfred -
Alfred NESWADBA
Message 12 of 12
dcolley_ptfnola
Thank you sir.  Have a great one.
David Colley
New Orleans, LA
David Colley
New Orleans, LA
AutoCAD Inside the Factory
