Hi @Anonymous
The red cross symbol appears next to the cursor when initiate the "ERASE" command and try to select the object to erase. But during that time the cursor will become a pickbox instead of being as a cursor.
I guess what you are seeing to be a graphic glitch. Try restarting your system and then run AutoCAD and you would see it vanish 🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
