Scaling paperspace automatically and formating
Hi Guys,
Please see the attachment "Paperspace scale".
I have found a method of creating a dynamic scale on the paperspace if I do the following instruction:
Have PageSpace activated
> CMD: Field
>Field Name: Object
>Object type: Viewport (click on PageSpace)
>Property: Custom scale
>Format: Use scale name
CMD: REGEN (To automatically update fields)
The problem I have is that the automatic scales this way appear as the following format "1:XX.YYYY"
I would rather the scale be rounded to the closes "1:XX"
Any ideas?
James
My other related question is regarding "Scale.jpg" see attached.
I am wondering if it is possible to make a dynamic scale (similar to google maps when zooming in and out) that shows a length and how many mm or m that distance is on that drawing?
pendean
Community Legend
Community Legend
1) Like this perhaps or something else https://forums.autodesk.com/t5/autocad-forum/lisp-to-create-viewports-from-modelspace/td-p/8777003
2) You'll need to do that scale bar manually as a dynamic block perhaps.
imadHabash
You may need to select the VP itself .
Imad Habash
Alfred.NESWADBA
if the evaluated field shows like "1:98.8497" then this means you have not a valid scale assigned to this viewport.
Rounding the value may show a value you want to see, but this would not be the correct value. Therefor I strongly recommend to assign a valid scale to the viewport, then you do not have the need to round this value.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
