LISP to create viewports from modelspace
Message 1 of 14
I am looking for a LISP program that is able to create a viewport in paper space from model space selection. Does anyone know of one?
I found the thread below and the lisp seemed to "nearly work" I guess? It worked a few times but would often give back an error.
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/lisp-to-create-viewport-from-selecte...
Thanks!
Michael
Replies (13)
Message 2 of 14
maratovich
Use search.
Or that :
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
Message 3 of 14
vladimir_michl
Message 4 of 14
pendean
Community Legend
Community Legend
Message 5 of 14
Thanks everyone. These all look great, but I'm having a hard time getting them to download with our firewalls and what-not. I work for state government and I have yet to try and figure out how to download apps like this.
That's why I thought there might be some lisp code that I could just plug into VLISP.
Thanks!
Michael
Message 6 of 14
pendean
Community Legend
Community Legend
Ask your I.T. for guidance/assistance with the tools you need to do to complete your work.
Message 7 of 14
davinatkins
Michael, what version of AutoCAD are you using?
Versions of AutoCAD later that 2018.2 make it really easy to place model views as viewports. Both named and unnamed.
If you have one of those versions, go to a paperspace view. On the layout tab - near the left - is a button Insert View. You you already have a named view, you just choose that. If you don't have a named view it'll automatically take you to modelspace and invite you to draw a rectangle around the area you want. Hit enter when you are happy with the rectangle. That shoots you right back to paperspace, where you can click to place that viewport - or right-click to change the scale beforehand.
You can't select an object as your boundary - like some of the other answers do - but you didn't say you needed that so maybe this does what you wanted?
Message 8 of 14
Oh great. I was having a hard time finding it for a few minutes, but I found it! Thank you this is exactly what I needed.
I do have Civil and AutoCAD 2019.
Thank you,
Michael
Message 9 of 14
Ed__Jobe
The icon might be new, but its just the New option of the MVIEW command.
Ed
How to post your code.
Message 10 of 14
I did notice that.  And I've been using a shortcut for MVIEW all this time. As I am all for quick commands via LISPs, how would I create a command to automatically choose "NEW" after initiating the MVIEW command?
Michael
Message 11 of 14
Ed__Jobe
For a menu macro in the cui, "^C^C mview NE ", but that's what the UI already does in the context-sensitive Layout ribbon tab. If you want a lisp so that you could create a two letter command, then use:
(defun C:NV () (command "mview" "NE"))
Now you can type NV for New Viewport.
Ed
Message 12 of 14
That's funny I was just doing exactly what you suggested. I found a Zoom All lisp just like that  (defun c:za() (command "zoom" "all" "")). Out of curiosity, I noticed that my lisp has another set of quotations marks ("") after the two command inputs and yours doesn't. Are they unnecessary?
Thank you for the reply!
Michael
Message 13 of 14
Ed__Jobe
The (command) function takes separate strings as arguments. The last empty double quote you refer to is like hitting the {Enter} key. So, whether you add that or not is context sensitive. Does the command require it? The ZOOM command needs it to execute the options. The MVIEW command doesn't need it, as its waiting for user input to select a window.
Ed
Message 14 of 14
Ah yes! Now it is clear, thank you!
