I am trying to make paper model of a complex solid (compound of five cubes). I don't understand how can I make an unfolded flat image which i can print and fold and stick together to make the complete solid.
One way I think this can be done is by manually tracing shapes of small surfaces and making it out of that.
But I cant seem to trace the shapes as the software doesn't recognize the intersections of cubes.
I have attached my solid here.
Explode the 3D Solid(Every face will be a separate element after exploding) and Move/Rotate the solids to match the expected unfolded view and then print it
SALMANUL FARIS
I would have done it for you(But I am working on Autocad 2016 and your file is of higher version), But it'll help you understand if you do it on your own.Post here, If you still need assistance.
SALMANUL FARIS
