How to Add Compass to the Viewport?
I am new to AutoCAD and using version 2019.
I am trying to add compass to the drawing viewport.
Please refer to the attached document which shows a compass in 2015 version but I do not see that in 2019 version.
I tried several options and checked on the internet to find the potential solution.
However, it did not help.
Could you please let me know a solution for the same.
I will really appreciate your help.
Neeraj
user181
Hi @Anonymous ,  Set the variable NAVVCUBDISPLAY to 3
Thanks for replying.
I did the following:
1. Typed NAVVCUBEDISPLAY in the command prompt (There was no command NAVVCUBDISPLAY)
2. I saw "Enter new value for NAVVCUBEDISPLAY <3>:" and I typed 3
3. Hit Enter key
Result:
I still do not see the compass in the viewport. it looks the same as shown in the screenshot (2019 version)
Could you let me know if I followed your instructions correctly.
Neeraj
Alfred.NESWADBA
can you look to command _OPTIONS and these settings?
If that does not work then please use command _GRAPHICSCONFIG and turn off hardware acceleration, start a new drawing and look to the viewcube, is it now displayed?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Hi Alfred,
The OPTIONS setting worked for me. It did not have a check on 2D Wireframe Visual Style
Thank you so much.
I just have a follow-up question to this:
Is there a way to set the compass using the GUI (I mean browsing through the toolbars)?
Thanks once again.
Neeraj
S.Faris
Check The attachments
  1. While Inside a Viewport
  2. While in Model Space
SALMANUL FARIS
Hi Faris,
It worked!
Thank you very much
Neeraj
