AutoCAD Forum
Unable to edit block
29 REPLIES 29
Message 1 of 30
34415 Views, 29 Replies
Unable to edit or explode the block that has been created with an unsupported character. Example "*plan".
29 REPLIES 29
Message 2 of 30
Alfred.NESWADBA
save the drawing as DXF, then use a texteditor (like notepad++ or something similar which is able to handle large files).
Then you can replace "*plan" to "xplan", save the file and open the dxf then in AutoCAD.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Message 3 of 30
piyush.parihar24
Can You Share the Screenshot of error message? It will be good to understand
Message 4 of 30
TheCADnoob
Im not sure this will help but does BURST do anything for it?
CADnoob
Message 5 of 30
wgoenen
Not sure if this would work either, but have you tried "rename" to remove the unsupported character?  I might even try "-wblock" and make it a file that I can rename, then purge the bad named block.
Message 6 of 30
john.vellek
Hi @Anonymous,
Can you share the drawing that contains the block? I would like to see if I can help.
John Vellek
Message 7 of 30
in reply to: john.vellek
Hi John,
Please see attached file.
Message 8 of 30
in reply to: piyush.parihar24
Hi piyush.parihar24,
Message 9 of 30
john.vellek
HI @Anonymous,
I am afraid your attachment didn't come through. Try adding it to a zip file and attach it again please.
John Vellek
Message 10 of 30
Hi John,
Please see attached files.
Message 11 of 30
RobDraw
It's an MINSERT which list does not tell you. FLATTEN is supposed to make it so it can be exploded but it is failing because of a "invalid complex object" in the block. I'm pretty sure there is a way around this but can't remember where I've seen it.
Rob
Message 12 of 30
jporter
in reply to: RobDraw
@RobDraw, not sure how you figured out it was an MINSERT block, but kudos to you.
If it truly is an MINSERT block then this may do the trick:  http://cadtips.cadalyst.com/edit-blocks/explode-minsert
Also, what is up with all the unnamed blocks in the drawing?  Not advisable to copy and paste so much:
Jason Porter
ASTI Civil Solutions Technical Advisor
www.asti.com
Message 13 of 30
RobDraw
in reply to: jporter
It was as simple as checking the properties.
Rob
Message 14 of 30
jporter
Well, DOH on my part. LOL. I only listed the item.
Jason Porter | Senior Civil Technical Advisor
512.758.7346 (d) | 800.899.2784 (o)
jporter@asti.com
Applied Software | Consulting, Services, Software, Go Further
10801 N. Mopac Expressway | Bldg 1, Suite 320
Austin, TX 78759
www.asti.com
[cid:image001.jpg@01CFAB10.C310FA90]
NOTICE: This communication may contain privileged or other confidential information (including attachments). If you are not the intended recipient, or believe that you have received this communication in error, please do not print, copy, retransmit, disseminate, or otherwise use the information. Also, please indicate to the sender that you have received this communication in error, and delete the copy you received. Thank you
Jason Porter
www.asti.com
Message 15 of 30
john.vellek
Hi @Anonymous,
i opened your drawing and verified that it was indeed a MINSERT.  So, I used BE (Block Edit) to open it, I did a select all, copy and then pasted into a new drawing.  I hope this helps.
Please select the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
Message 16 of 30
RobDraw
This does not work for me in MEP 2016. The block does not appear in the list in the dialog box and no option to select it that I can see.
Rob
Message 17 of 30
john.vellek
Hi @RobDraw, I can't speak for MEP [just a vanilla forum here :)].
The actual block name is 20160114_DUSIT_1
John Vellek
Message 18 of 30
RobDraw
That is a block within the MInserted block. It is not the entire drawing.
Rob
Message 19 of 30
john.vellek
Hi @RobDraw,
Right you are! I apologize but I got interrupted mid-process....
After I copied and pasted the things I could capture using Block Edit there wasn't much remaining. The last few items i simply plotted to a PDF and then inserted as vector geometry using Import PDF in 2017.
Thanks for catching that!
John Vellek
Message 20 of 30
elshawadfy
Hi @Anonymous,
Try this:
- DGNEXPORT (Some entities - most likely attributes may not make it) -- Follow instructions..
- DGNIMPORT in a new file (uncheck insert in this file - top left))..
An explodable dwg attatched (missing some attributes and maybe some other objects..)..
Blocks starting with * are called Anonymous Blocks, and AutoCAD generates them automatically to handle a lot of things.. for example when changing attribute definitions in an already used blocks, or change a parameter in an inserted dynamic block, or when creating groups, or o handle dimstyles....
They usually can't be inserted directly into the drawing, and can't be edited directly.. some lisps use that as a mean to provide some protection to blocks..
You can insert an anonymous block using the -insert command if you already know the name of the block..
Regards..
Forma Design Contest
