AutoCAD 2019.1.2 (product version: P1.62.0.0)
I've been struggling with creating multi-sheet file PDFs and having them look correct consistently. In general, I use one or two Page Setups with the AutoCAD PDF (General Documentation) pc3 file and a custom CTB file. Nothing crazy.
The issue:
- If I PLOT a single sheet to PDF, the output looks fine.
- If I PUBLISH a single sheet to PDF, the output (usually) looks fine.
- If I PUBLISH multiple sheets to a multi-sheet PDF file, the output does not look fine *.
- * I could get in to specifics about the differences in output, but I really don't want to cloud the issue... I should be able to use any one of the three methods above and get EXACTLY the same results, as long as I use the same named Page Setup each time.
For publishing multiple sheets, I've typically hit PUBLISH, select all sheets listed in the dialog box that appears, and then select the correct Page Setup to use (via the Page Setup for the first sheet listed):
Through trial-and-error, I found that if I changed the "Publish to" and "PDF preset" (from "Plotter named in page setup") that I get the correct output when publishing multiple sheets...?
Stranger still, if I go back to my original method of publishing, I get the correct results no matter what I do now...? What happened!?! How did this seem to correct itself?
Another oddity to share:
I used to use the DWG to PDF pc3 file when plotting/publishing... when I published (not plotted), I noticed that even though the DWG to PDF pc3 was listed in my Page Setup, it was ignoring that setting and decided to use the AutoCAD PDF (General Documentation) pc3 file instead (which is why I use this PC3 file now)?
Do the Output>Export to DWF/PDF settings override all others now (or have some influence)?
So confusing.... this makes no sense.
