AutoCAD Forum
Unable to edit block
29 REPLIES 29
Message 1 of 30
34810 Views, 29 Replies
Unable to edit or explode the block that has been created with an unsupported character. Example "*plan".
29 REPLIES 29
Message 21 of 30
jporter
in reply to: elshawadfy
So did the lisp routine from Cadalyst not work???  It doesn't appear as though it was attempted.
Jason Porter
ASTI Civil Solutions Technical Advisor
www.asti.com
Message 22 of 30
john.vellek
in reply to: jporter
HI jporter,
I did try the lisp but it failed and I didn't take time top analyze why.  It was written in 2007 so I assumed it was not accounting for a lot of changes.
Thanks for your contribution.
John Vellek
Message 23 of 30
RobDraw
This has a familiar feel to similar topics on other forums. After a discussion, the OP (or even someone else) will post a link to a tool unlock drawings like this or for making "secure" drawings.
Locking drawings like this is an interesting concept, but in my experience, it has little actual value and is usually detrimental for someone in the end.
Rob
Message 24 of 30
gdefilo
in reply to: RobDraw
Hi all,
the anonymous block needs a definition in the AcadBlockTable and a recognizable name.
The lisp mentioned in this thread:
http://forums.autodesk.com/t5/autocad-2013-2014-2015-2016-2017/block-name/td-p/4781187
should work for this.
I tried it and it works: you can rename the "*U230" block and treat it just like any other block.
Look: the lisp is in shareware.
Hope this helps,
Giancarlo
Message 25 of 30
elshawadfy
in reply to: gdefilo
Hi @gdefilo, Hi everyone..
Unfortunately @Anonymous block here is "double trouble":
- It's an anonymous block.. so it can't be edited directly.. -> that's also why the lisp for MInserts that @jporter provided didn't work, it couldn't read the name and went searching for the block in support paths..
- It's an "MInsert", so it can't be exploded.. -> that's why your lisp renamed it, but it's still unexplodable..
But your lisp made it editable since it renamed it, so it was possible to get inside as @john.vellek did and copy every thing to a new file.. So thank you very much for pointing to the thread, and thank you very much @maxim_k for the code.. ( @jporter' lisp should work after that - but it seems it has some trouble still with some attributes or entities)
The contents of the block are in the attached dwg.. (some attribute values may be reset because it's a copy from within the block - It would have been very nice if @jporter's lisp worked since it restores attribute values but unfortunately it's not the case.. 😞  )
Regards 🙂
Message 26 of 30
thanks. It worked for me
Message 27 of 30
in reply to: john.vellek
Thanks John.
Message 28 of 30
john.vellek
Hi @Anonymous,
You are welcome. I am glad you found a solution!
John Vellek
Message 29 of 30
in reply to: piyush.parihar24
Message 30 of 30
Alfred.NESWADBA
I can't see which type of object and how many objects are selected in your screenshot.
It might also be possible, that PICKFIRST is not set to 0 on your system.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
AutoCAD Inside the Factory
