AutoCAD Forum
Traveling Tangent Lines
7 REPLIES 7
Message 1 of 8
434 Views, 7 Replies
This may be an easy fix but it's been difficult Googling exactly what I'm looking for. I guess the best way I can describe my issue is with an example. Let's say I constrain a line tangent to a circle. If I grab the two objects and move them, the line will stay tangent but it will travel off to one side or another. The circle will go to wherever I move it to. I hope that makes sense. Is there a way to keep that where it is and not fly off and do it's own thing?
Tags (1)
7 REPLIES 7
Message 2 of 8
imadHabash
Hi and Welcome,
maybe if you fix object by using GCFIX command line will help.
Imad Habash
Message 3 of 8
in reply to: imadHabash
That seems to fix the object where it is in model space. I would basically like to fix them together. Good start but I would still need to be able to move the items.
Message 4 of 8
imadHabash
you can get it by adding another parametric option called HORIZONTAL ( see attached ) there you can move both together.
Good Luck...
Imad Habash
Message 5 of 8
JDMather
It sounds to me like you also need a coincident constraint between the line endpoint and the circle.
I have found that the easiest way to get a Coincident to a circle is to use the Nearest osnap.
Message 6 of 8
JDMather
@imadHabash wrote:
you can get it by adding another parametric option called HORIZONTAL ( see attached ) there you can move both together....
What if you don't want the line constrained to Horizontal?  I think you still need a Coincident, even if you do.
Message 7 of 8
in reply to: JDMather
The coincident constraint works, so thank you for that! I guess I was just looking for a global solution, so it would know to not travel automatically. Like a inferred constraint, I suppose. But CONSTRAINTINFER doesn't fix the problem. So for now I will use coincident as a hotfix! Thank you again.
Message 8 of 8
JDMather
Inferred coincident constraint is automatic if you use Nearest osnap.  Did you watch the video?  Do you see me adding any coincident constraints?  AutoCAD does it for me automatically.
Forma Design Contest
AutoCAD Beta
