Hi and Welcome,
maybe if you fix object by using GCFIX command line will help.
Imad Habash
you can get it by adding another parametric option called HORIZONTAL ( see attached ) there you can move both together.
Good Luck...
Imad Habash
It sounds to me like you also need a coincident constraint between the line endpoint and the circle.
I have found that the easiest way to get a Coincident to a circle is to use the Nearest osnap.
@imadHabash wrote:
you can get it by adding another parametric option called HORIZONTAL ( see attached ) there you can move both together....
What if you don't want the line constrained to Horizontal? I think you still need a Coincident, even if you do.
Inferred coincident constraint is automatic if you use Nearest osnap. Did you watch the video? Do you see me adding any coincident constraints? AutoCAD does it for me automatically.
