AutoCAD Forum
Transparency problem
10 REPLIES 10
Message 1 of 11
526 Views, 10 Replies
I have a problem plotting solid hatches with transparency. The hatch is on a layer with 50% transparency. When plotting the whole layout becomes faded like if the line weight is not plotted.
10 REPLIES 10
Message 2 of 11
Alfred.NESWADBA
some questions:
  • which version of AutoCAD (and service pack) are you using?
  • which visual style does your viewport have (or option "shade plot")
  • have you tried different plotters, e.g. "DWG to PDF.pc3" or which plotter have you tried
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Message 3 of 11
imadHabash
>> the whole layout becomes faded like if the line weight is not plotted.  <<
  • would you please show us an image for this faded layout.
  • also show us an image for the plot dialog after preparing your settings.
Imad Habash
Message 4 of 11
in reply to: imadHabash
Here you are! I do not have any transparency for any layer! Neither do I have view port override!
Message 5 of 11
Alfred.NESWADBA
you started with:
Now you showed 2 PDF files ... and I can't see any solid hatch in any of that PDF's. What am I missing?
- alfred -
Alfred NESWADBA
Message 6 of 11
john.vellek
Hi @Anonymous,
Is it possible to share the actual drawing file on a post? I would like to check out what is happening.
John Vellek
Message 7 of 11
john.vellek
Hi @Anonymous,
Have you fixed your problem? I haven't seen a new post from you.
Please let me know your status and if you can share a sample file.
John Vellek
Message 8 of 11
in reply to: Alfred.NESWADBA
But you can see that one is almost without line weight with plot transparency option on when plotting. Unfortunately I can not put the originals out here because those are company properties.
Message 9 of 11
in reply to: john.vellek
Please see my new post!
Message 10 of 11
Alfred.NESWADBA
from your first post
and now:
What does the original question "plotting solid hatches" have to do with your current PDF's ... or do you have a white solid hatch above the layout and therefor you don't see all in full color? I don't know but the data you showed yet does not give us the possibility for straight answers.
If you can't upload your file then please create a new file that shows us a similar situation and show us that file.
- alfred -
Alfred NESWADBA
Message 11 of 11
Alfred.NESWADBA
...and the questions of my first post are not answered yet, not any one of them.
- alfred -
Alfred NESWADBA
AutoCAD Inside the Factory
