the command line in acad 16 was outside drawing window now it is inside? why?
適用対象外
1,364件の閲覧回数
15件の返信
メッセージ1/16
適用対象外
The command line in acad 16 was outside drawing window now inside? why?
0 件のいいね
1,365件の閲覧回数
15件の返信
返信 (15)
メッセージ2/16
適用対象外
Previously in ACAD 16 the command line was outside of my drawing window. Now (?) It is inside and it blocks my cursor when I am dragging or moving or anything. How do I get the command line parked outside my drawing window? Having text of what I am doing planted in front of me is annoying. Help!!
0 件のいいね
メッセージ3/16
cadffm
If you really tank about the commandline: drag the commandline to the statusbar,
the shape changs to the full wide of program window, then drop it.
Not it is "docked".
Or do you talk about the dynamic input option? Set Dynmode to -3
If it doesn't solved your problem, upload a screenshot (and mark what you called "commandline")
Sebastian
0 件のいいね
メッセージ4/16
pendean
Community Legend
Community Legend
move it? it is not static unless you dock it.
0 件のいいね
メッセージ5/16
適用対象外
Hi, thx for the reply. I cannot drag the command line into the statusbar. I
don't know how it moved in the 1st place.
also there is a new transparent command line above the (small command line)
that tells me what I am doing (?) while I am doing it? How do I get rid of
that nasty thing?
- Please type your reply above this line -##
0 件のいいね
メッセージ6/16
cadffm
You know what "drag&drop" is?
drag
Click and hold the left mouse button (at the point you can see in my picture)
move the commandline (while holding the left mouse button)
drop
release the left mouse button (if you can see that the shape of the commandline changes, if not, try to drop it in the lower section, near the statusbar)
Sebastian
0 件のいいね
メッセージ7/16
pendean
Community Legend
Community Legend
HELP explains how to do it, did you get a chance to look there first? Here is the page from there https://knowledge.autodesk.com/support/autocad/getting-started/caas/CloudHelp/cloudhelp/2018/ENU/Aut...
As for the floaty... DYNMODE command perhaps, you can turn that off just like you did in acad16 too: explained in HELP as well.
0 件のいいね
メッセージ8/16
適用対象外
Yes, I know what it is. IT DOESN'T DRAG & DROP LIKE IT IS SUPPOSED TO.
Everything I try does nothing
0 件のいいね
メッセージ9/16
cadffm
Changes the cursor icon at this position i pointed too?
Is the ui unlocked?
LOCKUI
Sebastian
0 件のいいね
メッセージ10/16
適用対象外
Thanks for the help, Non of this worked;
1) The command line is inside my drawing at the bottom of the page, above the old status area. I can't drag my cursor thru it when I am drawing, I have to pan to get by it. Before it was out of the drawing area, now it is about 1/2" thick and about 3" wide, before I use only 2 lines & they were all the way across the screen and it did not interfere with my cursor. I have use every sort of attempt to relocate it but I can't get in, stretch, move, nothing
2) Now when I open my drawing about 2" of the drawing is not seen at all, because it is buried below? I have always had full screen view of my drawings. Limits have been set, full view is set..........nada.
3) Also there is a another (temp. ?) command line that pops up every time I use a command, mouse or keyboard. For some reason it is showing everything I am doing up to about 5 lines of text. All of which blocks my cursor (see 2). Why is this being written at the bottom of my drawings?
4) When this all started to mess up by itself, I went to my workspace & it gave me some kind of generic acad junk instead of my own file. So I had to re do all of my tools!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
5) I had to change to ACAD 17 because of a problem ya'll had with 16. I asked if I should delete 16 and was told no. Now my ACAD 17 is a turtle that was fathered by a slug. What do I have to do to get my computer back to normal?
Wish I had ACAD 9 or even 12 again......
0 件のいいね
メッセージ11/16
Alfred.NESWADBA
Please show a screenshot of your AutoCAD application window so we see which style your command-line has and where it is positioned.
Sounds like the command-line is NOT docked (moved downwards to the statusbar until you get a rectangle displayed and then release the mouse button).
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
0 件のいいね
メッセージ12/16
適用対象外
Hi Alfred. Right, the problem is I can't dock or undock it's like frozen
there. All just happened one day.
0 件のいいね
メッセージ13/16
pendean
Community Legend
Community Legend
Post screenshot of your full AutoCAD program screen in high res, let us see what you see. Don't know how to do that? Here is an explanation https://support.microsoft.com/en-us/help/4027213/windows-10-open-snipping-tool-and-take-a-screenshot
0 件のいいね
メッセージ14/16
vinodkl
Looks like you UI has been locked. Type in the command "LOCKUI" and set it to "0".
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
0 件のいいね
メッセージ15/16
ennujozlagam
 can refer to these LINK and LINK and see if helps. thanks
0 件のいいね
メッセージ16/16
Alfred.NESWADBA
can you please create a screenshot from what you have now?
Please follow these steps:
  • start command _CUI
  • on the left side select on your current workspace (the one marked with "current")
  • then on the right side/upper half open "Palettes" and select "Command Line"
  • change the settings to the ones in the screenshot:
- alfred -
Alfred NESWADBA
0 件のいいね
