Text writing
Text writing
ramjan3N9ZA
Message 1 of 8
Text writing
ramjan3N9ZA
Dear  experts
Is there any way to write dimension in drawings in any shortcut .
I hered there id=s a way is using roomdim comand.But I cant do this .
Please touch me
Regards
Ramjan
Replies (7)
Message 2 of 8
Vinayv4v
Please make your question clearer.
You cannot write dimensions using text. But you can add those symbols in the text which are required for dimension.
The correct way of doing is using the different dimension options in autocad.
You can use the QDIM option for marking the dimensions of a geometry easily.
If you are mentioning about correcting the value in dimension text without changing the geometry then you could approach this wrong method by double clicking on the dimension text and editing the value..
Cheers,
Vinay Vijayakumaran
Message 3 of 8
ramjan3N9ZA
Yes i can use qdim.
But I want to mean the use of "Roomdim" apps.Its may be .vlx file..
Have you know this.
Ramjan
Message 4 of 8
Alfred.NESWADBA
ROOMDIM is not a command for AutoCAD (Vanilla).
So you either have a vertical AutoCAD based product like AutoCAD Architecture or MEP ... then please ask in the forum for that product (>>>forum for AutoCAD Architecture<<<) ...or you have a plugin, then either ask the vendor of that plugin or at least please let us know which plugin that is!
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 5 of 8
ramjan3N9ZA
What is this ?
Please inform me.
Regards
Ramjan
Ramjan
Message 6 of 8
Alfred.NESWADBA
>> What is this ?
Part of a tool written by anyone else, but not Autodesk.
- alfred -
Alfred NESWADBA
Message 7 of 8
Kent1Cooper
Try using APPLOAD to Load that file, and type RM [the defined command name], and see what happens.  I have not tried it or studied it in detail, but it looks like it may label a room, but not dimension it.
Kent Cooper, AIA
Message 8 of 8
ramjan3N9ZA
Can you suggest me any site to download as like this tools.......
Ramjan
