AutoCAD Forum
Opening design centre?
3 REPLIES 3
368 Views, 3 Replies
I am struggling to open the design centre, I know its control key and 2 but all that happens is '_adcentre appears in the command line - what am I doing wrong?
3 REPLIES 3
Vinayv4v
Try Command DC for design center and check whether its coming. Check LOCKUI variable is on. Make it to <0>
Also try to change your work space as it may be an issue of minimized palette.
Cheers,
Vinay Vijayakumaran
in reply to: Vinayv4v
Thank you for your help Vinay,
I've managed to find it now.
regards,
Dave.
Vinayv4v
Hi David,
Glad you found it.
Can you explain how you did it so others may find it helpful. (what was the problem?)
Cheers,
Vinay Vijayakumaran
Forma Design Contest
