AutoCAD Forum
Text writing
7 REPLIES 7
Message 1 of 8
ramjan3N9ZA
439 Views, 7 Replies
Text writing
Dear  experts
Is there any way to write dimension in drawings in any shortcut .
I hered there id=s a way is using roomdim comand.But I cant do this .
Please touch me
Regards
Ramjan
7 REPLIES 7
Message 2 of 8
Vinayv4v
in reply to: ramjan3N9ZA
Please make your question clearer.
You cannot write dimensions using text. But you can add those symbols in the text which are required for dimension.
The correct way of doing is using the different dimension options in autocad.
You can use the QDIM option for marking the dimensions of a geometry easily.
If you are mentioning about correcting the value in dimension text without changing the geometry then you could approach this wrong method by double clicking on the dimension text and editing the value..
Cheers,
Vinay Vijayakumaran
Message 3 of 8
ramjan3N9ZA
in reply to: Vinayv4v
Yes i can use qdim.
But I want to mean the use of "Roomdim" apps.Its may be .vlx file..
Have you know this.
Ramjan
Message 4 of 8
ROOMDIM is not a command for AutoCAD (Vanilla).
So you either have a vertical AutoCAD based product like AutoCAD Architecture or MEP ... then please ask in the forum for that product (>>>forum for AutoCAD Architecture<<<) ...or you have a plugin, then either ask the vendor of that plugin or at least please let us know which plugin that is!
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Message 5 of 8
What is this ?
Please inform me.
Regards
Ramjan
Ramjan
Message 6 of 8
>> What is this ?
Part of a tool written by anyone else, but not Autodesk.
- alfred -
Alfred NESWADBA
Message 7 of 8
Kent1Cooper
Try using APPLOAD to Load that file, and type RM [the defined command name], and see what happens.  I have not tried it or studied it in detail, but it looks like it may label a room, but not dimension it.
Kent Cooper, AIA
Message 8 of 8
Can you suggest me any site to download as like this tools.......
Ramjan
AutoCAD Inside the Factory
