Table's Blank Cells Issues
RocksterB
Message 1 of 19
RocksterB
Can someone inform me why when I copy and paste the cells in the provided drawing, some of the pasted cells are blank? This issue is occurring in version S.51.0.0 2022.
Replies (18)
Message 2 of 19
pendean
Community Legend
Community Legend
@RocksterB While you wait... your AutoCAD 2022 is not updated at all.
You want the 2022.1.4 Update, get it from your Autodesk Account Page here https://manage.autodesk.com/cep/#products-services/updates
Restart your PC afterwards.
FYI, no issues at all using copy/paste in your table with your cells
Perhaps there is something else we need to be doing first that you did not mention yet?
Message 3 of 19
Valentin_CAD
@RocksterB ,
Take a look at this:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Message 4 of 19
cadffm
@pendean
copy rows 1-
@Valentin_CAD
But we copy from and to autocad, inside the same table
Sebastian
Message 5 of 19
pendean
Community Legend
Community Legend
@cadffm wrote:
@pendean
copy rows 1-
But why copy/paste anything from row#1? OP never mentions that as the only issue. but OK, it still works fine here, but I'm not running original not-updated 2022 at all
Message 6 of 19
cadffm
I can reproduce it in some versions.
Sample picture from 2025.1
red: Original data and my cell copies (I miss some values)
blue: additional new values and the cell copies (works well)
Sebastian
Message 7 of 19
cadffm
1. SORRY, I mean row 2-5
TO: why when I copy and paste the cells in the provided drawing, some of the pasted cells are blank?
It happens with the existing content (row 2-5, or better with row 3+4 only, column A+B / 3A+3B+4A and 4B)
I can not see the copy of row 2-5 in your picture.
Sebastian
Message 8 of 19
pendean
Community Legend
Community Legend
Got it. I  did not test in AutoCAD2025.1. Check cell locking, more often than not many are unlocked, a few are not. Same for formatting. And data type.
Message 9 of 19
cadffm
If some others want to try the clean test to reproduce it (I guess the version doesn't matter, I tried different from 2021-2025)
ALL steps I did:
I opened the original file,
selected cell A2->C5  (by click in cell A2,  and in C5 while holding shift), ctrl+c
selected cellA6, ctrl+v
My result, see attached file below.
A7-B8 empfty (no content), expected: The same content as in A3-B4
(and it doesn't matter if i unlock all cells or not)
Sebastian
Message 10 of 19
pendean
Community Legend
Community Legend
@cadffm wrote:
If some others want to try the clean test to reproduce it...
See attached: unlocked all cells and matched formatting.
Message 11 of 19
cadffm
Hi Pendean,
from me too, thanks for testing.
I know what I can do to get another result, but
1. I don't know why it doesn't work with such edits
2. I can't see the difference betwenn A2 and A3 for example, or B3 and B4 ..
3. No matter the formats are, the expected result is to get content
I think becaue of your answers, you also can reproduce the issue (by following my introduces), that's good.
@RocksterB
I can't explain it.
Whatever the issue is, it has to do with corrupt(unexpecting) data of your cells.
See Pendeans reply
Sebastian
Message 12 of 19
RocksterB
I believe this is one of those rare times where there is no solution. Thank you for all your assistance.
Message 13 of 19
paullimapa
So out of curiosity how was this Table created? Was it copied from Excel or another program?
Paul Li
IT Specialist
@The Office
Message 14 of 19
RocksterB
The data in the cells of this table was added manually. Excel was not involved.
Message 15 of 19
paullimapa
So this was a Table created from AutoCAD. Does this happen every time a new Table is created? What AutoCAD version are you using ? Enter About command and share the build #
Paul Li
IT Specialist
@The Office
Message 16 of 19
RocksterB
This issue doesn't occur in newly created tables. The tables with the problem happens to be in multiple files. I just provided a snippet of the actual long table. The AutoCAD version is S.51.0.0 2022, which is what must be used at this time.
Message 17 of 19
paullimapa
It’s good that the problem doesn’t occur with newly created Tables. Do you recall if these tables were originally created using this version of AutoCAD or with a previous version?
Paul Li
IT Specialist
@The Office
Message 18 of 19
RocksterB
The tables were created back in AutoCAD 2018.
Message 19 of 19
paullimapa
I see a much older version. Thanks for documenting all this here.
Paul Li
IT Specialist
@The Office
