DIMENSION TOOLBAR
DIMENSION TOOLBAR
shoslerBHLL5
DIMENSION TOOLBAR
shoslerBHLL5
I'm normally pretty good at figuring out issues but I cannot figure this one out. The dimension toolbar has split into shorter toolbar with 2 lines. Normally its one line all the way across with all the different icons.
I usually dock it at the top and hide it in the open file tab area as to not shrink the screen.
Anyone have any ideas on how to fix this?
cadffm
drag it like other windows too.
move the cursor to the top or bottom line,
if the cursor icon change , press left mouse button
and move your mouse.
Sebastian
shoslerBHLL5
I'm able to move it around. That's not the issue.
pendean
Community Legend
Community Legend
I don't think you understood the last reply. Let's try again:
1) turn off LOCKUI command (look it up in HELP in the program if needed).
2) move your cursor to the bottom of that TOOLBAR, it changes to a two-directional arrow.
3) move up/down to see what display choices toolbars in AutoCAD offer.
4) settle on one toolbar display you like.
5) set LOCKUI back to what you had it.
6) use WSSAVE command to save your current workspace.
7) repeat if you jump between many workspaces in your AutoCAD.
HTH
shoslerBHLL5
You get gold star. Thanks. So much appreciated for your help.
