Shift key will not toggle ortho mode - tried all solutions
netaoren
Message 1 of 54
netaoren
Autocad 2025
It's the common problem - my shift key won't toggle ortho mode
I have searched and tried all solutions on this forum:
*Options (>user preferences) settings are fine
*TEMPOVERRIDES is fine
*PICKADD is fine
*Temporary Override Keys on CUI is as it should
*I have checked my keyboard, the key works and deselect by shift key is working just fine.
I prefer not to reinstall the software just for that - so I'm looking for other solutions.
thanks!
Replies (53)
Message 21 of 54
treyAPKQN
Community Visitor
Community Visitor
I'm having the same issue, and I uninstalled the widows update and the issue went away, but somehow the update was forced on my DELL laptop two nights ago and now I can't use the shift key again. I tied to uninstall the update again but the shift key is not working.
Message 22 of 54
JBerns
Perhaps there is another Windows update after the KB5083769 update that re-introduces the issue.
Do so at your own rick, but try uninstalling other Windows updates after April 14.
CAD Administrator
Using AutoCAD & Inventor 2025
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
Message 23 of 54
cjmcad09
It's working again today. Has anyone else found this to be fixed?
Message 24 of 54
officeU9MEL
Observer
Observer
Also , pressing both shift keys will act not as a toggle while pressed, but a one time press working while the command is active ( line, pline). Deactivating it while the command is active can be done by pressing Left Ctrl. Strange.
Also, i uninstalled the Windows update after the KB5083769 and it does not work for me. Shift still not working.
Message 25 of 54
Gene.Brode
This problem just started for me this very morning. My laptop is managed by my organization and is on Windows 11. According to my system updates, the last update I had was in February of this year. Uninstalling this update may work for some, but it's technically not the cause of the OP's problem which dates back to 2024. Since I didn't have any issues Friday afternoon, and I don't have this 4/15 update, it can't be what's caused the issue for me today. It's quite strange.
For posterity's sake, I am using a wireless ProtoArc keyboard that sometimes acts up when it needs recharged. I have it plugged in and charging now, but the problem persists. I have checked all the settings in the original post list as well, and made sure my Shift key works otherwise.
Message 26 of 54
Gene.Brode
This works for me, but now how to I get my hand back on the mouse to click where I need my polyline to go? LOL
Message 27 of 54
cjmcad09
Nope, never mind. It's not working again. It was working for a day but now it's not working again.
Message 29 of 54
Gene.Brode
Thanks so much for that link! I could only get it to work by changing the Windows keyboard filter settings option. My ACAD gave me a hard time and would not let me edit the temporary override keys. Either way, I'm back in business. What's confusing, though, is why this happened for me at all since my Windows has not updated.
Message 30 of 54
netaoren
Hi, my issue was long before the system updat started this latest issue. Also i use a lenovo laptop.
Happy for all of thoes who had it fixed!
Message 31 of 54
AllenJessup
You can hit both Shift keys and then let one of them up. AutoCAD just need the second Shift to activate the override. Or you can hold down the F8 key. When it's held down it acts as a Temporary Override instead of a Toggle
Allen Jessup
CAD Manager - Designer
Message 32 of 54
Ed__Jobe
You might try going to Lenovo's support site and see if they have a driver for the keyboard. That might reset whatever a Windows update did. This problem seems to be very specific to certain laptops.
Ed
How to post your code.
Message 33 of 54
ext_travis_miller
Observer
Observer
same for me, please fix this ASAP AUTODesk.
Message 34 of 54
ext_travis_miller
Observer
Observer
Message 35 of 54
officeU9MEL
Observer
Observer
Ok, i have a solution , but you must have a Logitech mouse with alot of buttons. I use a Logitech G502. So in the Logitech application you can set up a mouse button ( i use the big button at the right side of the mouse that is used as DPI Shift), i set it up as a multi key press and selected both shift key pressed. It works for me.
Message 36 of 54
ext_travis_miller
Observer
Observer
I have a Logitech ergo m575 mouse, but can not put the mouse button for both shift keys. I did make one of them toggle the F8 key and thats a decent work around.
Message 37 of 54
Gene.Brode
Thank you! I didn't think there was actually a way. Plus changing my keyboard accessibility options has not disabled my backspace from working when I hold it down to delete large portions of text. Oh well.
Message 38 of 54
joshuarKG2N8
Thank you so much for doing the legwork necessary to bring the actual solution to light, I and many others appreciate it.
So glad there's people like you on this site who,
unlike some people who insult others and post links telling them to open a futile case with the AutoCAD support team,
actually want to help other users. 😊
Message 39 of 54
h_s_walker
For any who are still trying to find a fix see this thread
Solved: HotFix for Shift key not working / toggling - Autodesk Community
Howard Walker
Left Handed and Proud
Message 40 of 54
eto_109
AutoCAD製品はWindows 11、25H2、OSビルド26200.8246にWindows Updateをインストールするとフリーズまたは動作停止します
This text was posted using machine translation from Japanese.
A hotfix has been released for a freezing issue caused by the KB5083769 update.
Do you think this might be related to this Shift key issue?
