Geometry Cleanup Multiple Selection/Select All
idoQEYMP
idoQEYMP
I just ran the new to version 2027 geometry cleanup tool on a file I got from a colleague and got over 700 corrections. I noticed I have to select the found issues one by one to apply a fix. Can we have a "select multiple"\ "select all" on this tool? Does it exist and I missed it?
pendean
Community Legend
Community Legend
@idoQEYMP You missed nothing: hopefully this tool will do more in future 2028-29-30 versions in the next few years.
ChicagoLooper
@idoQEYMP
Geometry cleanup will detect possible errors. Some of the detections will need correction while some won't because they might not actually be errors, they're part of the design. Geometry cleanup won't use 'judgement' to determine which detections are real-deal errors and which ones must remain so cleaning up the errors simultaneously, both the good and bad, isn't part of the cleanup.
It seems to me the errors occur when the drawing is being originally created or when it's being exporting from another program that can't spit out a clean, AutoCAD friendly, drawing. The original author or the user with the exporting program could use you input because they're the ones that can fix it.
If you're using geometry cleanup, it's up to you to use discretion.
Chicagolooper
obulesub
Hello @idoQEYMP ,
Just checking in—did the responses shared by ChicagoLooper, pendean  help clarify your question?
If so, please consider clicking the "Accept Solution" button. Doing so helps others in the community find answers to similar issues.
If your question still needs more attention, feel free to reply here with an update. This way, other members can jump in with further suggestions or guidance to help you move forward.
Obulesu | Community Manager
obulesub
Hi @idoQEYMP,
Did the responses from pendean and ChicagoLooper helped addressing the request. If yes, please click on accept solution or if you need any further, please add your comments on the thread.
