im not able to select the assembly as my assembly is more than 200 objects i cant edit not move the objects .this is almost useless ..and there is no option of increasing no of selection of objec
A few screenshots explaining the term assembly and specifying objects will help to give an answer.
Have you tried using blocks for objects?
I'm with @alex101000 ... the termn "assembly" is nothing used in AutoCAD, which type of object do you really have? Please select it and let us know what the property windows shows as object type.
Can you please describe what you mean by "I can not .."? What steps did you do and what did AutoCAD respond to that?
What happens if you start command _MOVE, then select your objects, then show reference point and then destination point ... which step is not possible and why, what do you see on your screen?
- alfred -
>> Enter new value for PROPOBJLIMIT <25000>
Sorry, this is only a limit for the property window or property modifications like object's layer, color, lineweight ... , this value is not responsible for object selection to move or copy objects.
- alfred -
