AutoCAD Forum
copying blocks into drawing not to same scale as drawing??
9 REPLIES 9
Message 1 of 10
517 Views, 9 Replies
I need some help, I have a floor plan that was imported from a PDF, but when I try to copy in blocks from other drawings they come out absolutely massive?  overshadowing the floor plan.  Can some one help me please. Thank you.
9 REPLIES 9
Message 2 of 10
pendean
pendean
Community Legend
Community Legend
The units in your source file are different from the units in your destination file (feet vs inches, meters vs mm, miles vs inches and so on).
Message 3 of 10
jporter
in reply to: pendean
jporter
Type in UNITS at the command line and verify the insertion scales are the same for both drawings.
Jason Porter
ASTI Civil Solutions Technical Advisor
www.asti.com
Jason Porter
www.asti.com
Message 4 of 10
Hi, thanks for getting back to me so quickly.
Both the units in the floor plan and the units in the block i'm importing are set to mm?
I'm relatively new to this, so please be kind to me. Smiley Happy
Thank you.
Thank you.
Message 5 of 10
in reply to: jporter
Thanks for getting back to me.
they are both set to mm?
Message 6 of 10
jporter
jporter
Are you pasting them into the other drawing or are you inserting it in?  If your inserting, verify the scale is set to 1, 1, 1.  If you're pasting then the issue could be in the block.  Have you taken a look at the dimensions of the original block in the block editor?  Or can you provide us the drawings to review ourselves?
Jason Porter
www.asti.com
Jason Porter
www.asti.com
Message 7 of 10
RobDraw
RobDraw
I'm betting the import was not scaled up to 1:1 and is still in paper space dimensions.
Rob
Rob
Message 8 of 10
in reply to: RobDraw
how can I check this?
Message 9 of 10
RobDraw
RobDraw
Measure a known distance.
Rob
Rob
Message 10 of 10
gotphish001
gotphish001
Open up just the block dwg. Check the units and measure the block. If it's not what is expected, you can scale it up or down with SCALE with the reference option to what it should be. Save it and it should insert correct from now on.
Nick DiPietro
Cad Manager/Monkey
Nick DiPietro
Cad Manager/Monkey
AutoCAD Inside the Factory
