AutoCAD Forum
Selecting import, attach, open, does not open window
3 REPLIES 3
553 Views, 3 Replies
Instead of opening a window where I can select file to be imported (in this case a point cloud) the command: "Insert file name" appears instead. Same goes for attach, open, etc. Did I accidentally change a setting?
3 REPLIES 3
martti.halminen
Yes you did.
FILEDIA
- typically happens if you crash or cancel a sloppily written program.
Valentin-WSP
@Anonymous ,
Just for reference:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
in reply to: martti.halminen
Thank you
Forma Design Contest
