Instead of opening a window where I can select file to be imported (in this case a point cloud) the command: "Insert file name" appears instead. Same goes for attach, open, etc. Did I accidentally change a setting?
Solved by Valentin-WSP. Go to Solution.
Solved by martti.halminen. Go to Solution.
Yes you did.
FILEDIA
- typically happens if you crash or cancel a sloppily written program.
@Anonymous ,
Just for reference:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
