Selecting import, attach, open, does not open window
Instead of opening a window where I can select file to be imported (in this case a point cloud) the command: "Insert file name" appears instead. Same goes for attach, open, etc. Did I accidentally change a setting?
martti.halminen
Yes you did.
FILEDIA
- typically happens if you crash or cancel a sloppily written program.
Valentin_CAD
@Anonymous ,
Just for reference:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Thank you
