I'm not sure this is the correct place to post this so pardon my ignorance,
I have a User with a problem :
When they open a Autodesk DWG Trueview file on a server 2008 R2 the file opens normally, However when it's opened on a Server 2012 R2 the lines are scattered all over the place. Similar to this post :
http://forums.autodesk.com/t5/dwg-trueview/display-shows-scattered-lines/td-p/5044348
has there been a fix to this issue? or is the only solution uninstall version 2015 and install version 2013? what if this isn't the current version installed, or i am not allowed to uninstall version 2015?
thank you for your time
Stefan
Solved by pendean. Go to Solution.
