AutoCAD Forum
scattered Lines depending on OS
3 REPLIES 3
327 Views, 3 Replies
I'm not sure this is the correct place to post this so pardon my ignorance,
I have a User with a problem :
When they open a Autodesk DWG Trueview file on a server 2008 R2 the file opens normally, However when it's opened on a Server 2012 R2 the lines are scattered all over the place. Similar to this post :
http://forums.autodesk.com/t5/dwg-trueview/display-shows-scattered-lines/td-p/5044348
has there been a fix to this issue? or is the only solution uninstall version 2015 and install version 2013? what if this isn't the current version installed, or i am not allowed to uninstall version 2015?
thank you for your time
Stefan
Tags (1)
3 REPLIES 3
pendean
The video card on the 2012 Server is conflicting with the application. Get newer or older drivers or try this tip http://forums.autodesk.com/t5/dwg-trueview/dwg-true-view-hardware-acceleration/m-p/5554012#M19420
But since neither OS is supported though for that application, no one at Autodesk or Microsoft is going to give you much help. Good luck.
in reply to: pendean
Thanks alot  for the help dean, i will try this
Krgd
Stefan
Hello, just a quick update, the registry change fix worked perfectly, thanks alot, you're a lifesaver 🙂
Forma Design Contest
AutoCAD Beta
