Recently, I had 5 drawings open in AutoCAD. In one of them, I had an active command that I walked away and didn't realize it. I tried executing something from the Menu files and I crashed. It indicated that a .DMP file was created and gave me the path. Does this .DMP file contain all my drawing info and can it be recovered from AutoCAD environment? I have a temporary file saved but it's from 2 hours ago. I hate to lose 2 hours of work.
Solved by wispoxy. Go to Solution.
Look for your SV$ autosave file in the WIndows temp folder for your login if the BAK file that is created alongside your DWG file when you manually save is of no use.
HI @Anonymous,
I am sorry that you are experiencing such Meltdown!
The first thing I suggest is to copy all the SV$ files from your C:\Users\<USERNAME>\AppData\Local\Temp folder to a secure location. I would also do the same with any BAK files.
Now you can methodically rename the files as DWG files and explore what recoverability is available.
Please update your post if you require additional assistance.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
Hi ebottsUDG4J,
I am checking back to see if my post or others helped you with your problem. Please add a post with your results so other Forum users can benefit.
Please hit the Accept as Solution button if a post or posts fully solved your issue or answered your question.
I have had success converting .tmp files...just rename it to .dwg extension They are typically stored in the respective project file folder that you are using to save drawings.
