Deleting duplicate Blocks
MikeKovacik4928
Advisor Advisor
MikeKovacik4928
I  have tried the "overkill" command to find duplicate blocks placed on top of each other by mistake.
It doesn't seem to work for blocks, only entities, unless I am missing something.
Is there a way to do this?
At the moment, I have to select a single instance of a visible block, pretend to do an erase,
and see if it selects more than one. If there is more than one, say two.
I delete the top one by selecting, leaving the one below.
I then have to repeat this for all other visible instances of that same block.
This is an extremely laborious way of doing it.
There must be a better way, the "overkill" method would be much better,
if it worked!!
Michael Kovacik
AutoCAD 2d & 3d (29 yrs)& Inventor (7 yrs)
Manufacturing (30 yrs) Draughtsman
Autodesk Product Design Suite Ultimate 2018
Johannesburg, South Africa
pendean
Community Legend
Community Legend
So there are about a dozen options in OVERKILL command to select from: what did you select or try so far? The defaults do not work for everything all the time, you have to set parameters.
john.vellek
Hi @MikeKovacik4928,
I found some apps in the Autodesk App Store that might work better than the in-the-box Overkill. I haven't tried them but they might be worth a look.  I haven't found the OVERKILL to work that well with blocks either. You are welcome to attach a sample file if you would like me to see if I can come up with other workflows.
John Vellek
MikeKovacik4928
okay, I have set overkill to ignore all 9 object comparison settings, and it works with blocks selected.
Michael Kovacik
Autodesk Product Design Suite Ultimate 2017
MikeKovacik4928
Thanks for the offer.
Overkill seems to do the trick for me, once I have deselected all object comparison settings
Michael Kovacik
