AutoCAD Forum
AutoCAD Layers messing up on first time opening.
8 REPLIES 8
Message 1 of 9
505 Views, 8 Replies
I have been having difficulty with the layers tab when opening AutoCAD files upon initially loading AutoCAD files - they are all messed up and glitchy!
The fix that I have found is to close the whole program, and reopen it, then it appears to fix itself. This is an annoying glitch however, and I am curious as to why AutoCAD does this?
A note to add is that I have usually been loading files imported from Rhino, but the problem seems to always be there, non-dependent on the origin of the file.
I am using Autodesk AutoCAD 2016.
8 REPLIES 8
Message 2 of 9
RobDraw
Could you be a little more specific and/or provide screen shots?
Rob
Message 3 of 9
in reply to: RobDraw
Here is a screenshot - it appears to randomly occur.
The file has 3 layers, but only appears to show layer 0. You cannot stretch the layers tab to show the full details of the layers, nor make the layers which are not visible, visible.
Message 4 of 9
pendean
There is no cure for "random": can you find a way to trigger it on demand?
When this happens in the LAYER command palette, does it also happen in CLASSICLAYER command?
Or does the problem go away after you simply restart AutoCAD 2016?
Is R2016 fully patched and updated? It needs to be to work well in Win10.
Message 5 of 9
RobDraw
I've seen that many times. It's a graphics issue but not sure exactly what causes it. IME, it happens far less often on higher end machines. Tweaking graphics settings to be more performance based might help. Downgrading to the classic layer interface will work but, IMHO, it's not an acceptable workaround unless you are on the low end of the system requirements for AutoCAD.
A couple of things that have helped me in the past were reloading my profile. Make sure to save it before hand. And, changing workspace and changing back seemed to help but not permanently.
Rob
Message 6 of 9
Thanks RobDraw, that seems like the most reasonable solution. I have found my machine to lag at times, so perhaps it doesn't quite meet the requirements to run AutoCAD to the standard I am working at. The machine however was fairly high spec when I got it 3 years ago - 1GB dedicated graphics card and 8GB of RAM.
Message 7 of 9
pendean
>>>...1GB dedicated graphics card and 8GB of RAM...<<<
Those specs were "base" 3-years ago, nothing high spec about those choices sadly.
Message 8 of 9
john.vellek
Hi @Anonymous,
Does this behavior change if you un-dock the Layer Properties palette? Once you un-dock it. rt-click on the column headings and select Restore all Columns to Defaults.
Does that improve the issue?  If this happens mostly with files that came from Rhino can you attach one of those files for me to examine?
John Vellek
Message 9 of 9
john.vellek
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
AutoCAD Inside the Factory
