AutoCAD Forum
question 3d
2 REPLIES 2
250 Views, 2 Replies
question 3d
Dear sir /madam
I want to ask you something .i was making an exersice from a tutorial video and there was a problem when i press button house
or NE isometric i lost all circles with other words i lost this part
where is the problem now?and what i should make to fix it?
2 REPLIES 2
Alfred.NESWADBA
changing the view automatically zooms to extents, and looking to your video I would say
"No, the circles do not disappear, instead the rectangle appears" ... assuming the rectangle is far away from your primary drawing (the one you started the video with) and will be shown after zooming to extents.
When you changed the view in your video look to the area (zoom to that area) I marked from your screenshot, I guess there are the circles you are looking for.
If that does not work erase the rectangle and then run _ZOOM _EXTENTS, do you now see your circles?
HTH, - alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
JDMather
@Anonymous wrote:
...and what i should make to fix it?
Attach your *.dwg file here and someone will tell you exactly how to fix it.
Forma Design Contest
