publishing to PDF taking 8-10 hours
Waseem.MikhaelPLELV
Message 1 of 50
Waseem.MikhaelPLELV
Hello everyone,
I have a big issue that giving me a hard time to finish DWG. the publishing is taking a lot of time between 8 to 10 hours for a file that is 16MB size. I'm using Xref with Clip comments and the Xref file contains dynamic block.
please advise if there a way of speeding up this process. or if the Dynamic block I have is making the problem?
thank you in advance.
Replies (49)
Message 21 of 50
Waseem.MikhaelPLELV
@Alfred.NESWADBA yes I will for next time uploading files
I'm currently using 2021 full version
Message 22 of 50
Alfred.NESWADBA
Then you should use the current file format which is (currently) DWG-2018
First test is to run command _RECOVERALL ... and errors already found inside your files.
While this process seems to need a lot of time, you can already start with this while I'm continuing with tests.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 23 of 50
Waseem.MikhaelPLELV
@Alfred.NESWADBA ok I will do that for all files
Message 24 of 50
Alfred.NESWADBA
No, just with the main file as command _RECOVERALL does the checks within the referenced files automatically.
- alfred -
Alfred NESWADBA
Message 25 of 50
Waseem.MikhaelPLELV
@Alfred.NESWADBA ok I did.
Message 26 of 50
Alfred.NESWADBA
may I ask you how long your system needs to open the file (until it shows all tabs of layouts)?
Also why not using the AutoCAD PDF device (which is by default faster, better resolution and smaller PDF files)?
Why is the Bluebeam-PDF needed on your side?
- alfred -
PS: first tests look like I can reproduce it (even with a different software) so we really need to look into the files.
Alfred NESWADBA
Message 27 of 50
Waseem.MikhaelPLELV
@Alfred.NESWADBA it takes about 5 minutes to open the file.
using Bluebeam just because of the plot set-up
will that make the process fast if changing to AutoCAD pdf ? please advise I don't think it will be a big issue to use the autocad pdf plot style, just need to set-up the page size.
thank you
Message 28 of 50
Alfred.NESWADBA
OK, so we are on the limits of AutoCAD with these files, need now to find out, why...
Faster ... yes, but publishing this project will not change to a few seconds.
When not loading the XRef's, publishing seems to need about 2-3min for your 75 pages (on my system).
- alfred -
Alfred NESWADBA
Message 29 of 50
Waseem.MikhaelPLELV
@Alfred.NESWADBA ok looks like issue with Xref files and Blocks inside it. hope that you can find a solution for it. it will be really great.
Message 30 of 50
Alfred.NESWADBA
I started to dive into the single files, starting with "1ST FLOOR.dwg", what I see is that:
Above your real geometry I see a lot of hatches like that:
...and worse: if I select this hatch and see it's borders, I get this:
So you have outside the base geometry a lot of very complex hatches, which are even not needed, are they?
- alfred -
Alfred NESWADBA
Message 31 of 50
Waseem.MikhaelPLELV
@Alfred.NESWADBA I can't see these hatches. I don't know why.
Message 32 of 50
Alfred.NESWADBA
Open the "1ST FLOOR.dwg", activate modelspace and zoom extents. Then press <CTRL><A> to select all objects ... and be surprised ...
If you don't see geometry outside your "project area" then please start command _ABOUT and show me a screenshot of that dialog.
This is what I see doing the above steps ... (in AutoCAD 2022 and 2023 you see more, but in 2021 you see object selection at areas you don't think objects are placed)
Also there exist geometry on the DEFPOINTS layer, and even worse these are annotative blocks.
If you want objects to not plot, then create a new layer which has the property "No-Plot", but do not (never) use the DEFPOINTS layer, this is reserved for AutoCAD internal use.
And if you want objects to not be plotted, why then making them annotative?
- alfred -
Alfred NESWADBA
Message 33 of 50
Waseem.MikhaelPLELV
@Alfred.NESWADBA ok I see it. these received from original DWG. ok I will create a new layer with disable the plotting for it. for annotative. I will delete if it creating this issue.
Message 34 of 50
Alfred.NESWADBA
did this workflow:
  • copied based dwg and dwg's for floor 1 to 4 into a new folder (so when I open the base drawing he just finds 4 referenced dwg-files ... just for testing)
with these 4 files I did
  • command _ERASE with option _ALL and then option _REMOVE and a window selection around the "real" geometry (this removes the dead ones outside the project area)
  • command _QSELECT for all objects on layer "DEFPOINTS" ==> let the command select these items and then delete them
Then close and save these dwg-files, open your based drawing and run _PUBLISH.
This makes _PUBLISH a lot faster, so you'll need to execute this for the other floor-files and I guess you get back a valid speed for publishing.
This is my dialog for _PUBLISH and it's options:
- alfred -
Alfred NESWADBA
Message 35 of 50
pendean
Community Legend
Community Legend
I will concur with the finding others have expressed. Looks like a combination of you needing to talk with Bluebeam support along with some serious files cleanup/workflow changes may be in order to speed up your PUBLISH processes (how do you even navigate that top ELEVATIONS file?).
PUBLISH to a default PDF in that command pop-up took about 3-minutes here in R2021. Not using Bluebeam. Not using your predefined pagesetups. These may also be an issue.
Bluebeam support is very responsive if you ever need them or only wish to use their products, get to them here https://support.bluebeam.com/ 1 (866) 496-2140
Message 36 of 50
Alfred.NESWADBA
Really? Without the cleanup of these defect like objects and with XRef's loaded?
This would be faster than loading the dwg-file on my system 😉
Even with the cleanup (however with AutoCAD 2023, just started it) seems to need 5-10 minutes, while without cleaning it took more than 10min (with just 4 XRef's loaded) before I cancelled it.
3 minutes without XRef's would be the same as I got.
- alfred -
Alfred NESWADBA
Message 37 of 50
Alfred.NESWADBA
verified now, both AutoCAD 2021 as well as 2023 are using about the same time for _PUBLISH.
If you really have all 13 references loaded and publishing needs just 3min, then something on your system is very different to the OP's one and mine. Would be interesting to find this, however could need time 😉
- alfred -
Alfred NESWADBA
Message 38 of 50
Waseem.MikhaelPLELV
@Alfred.NESWADBA I've followed all steps with printing the as you've attached. still same issue slow.
I don't know why.
Message 39 of 50
Alfred.NESWADBA
ok, it's not done with 10min, it gets slower with each page, however, after about 20min now they (AutoCAD 2021 as well as 2023) are in the process "50 of 75" ... so at least much faster than 8-10hours 😉
- alfred -
Alfred NESWADBA
Message 40 of 50
Waseem.MikhaelPLELV
@Alfred.NESWADBA I have exactly followed the steps your provided. and still same issue very slow.
