How to delete a plugin
mdonovanPPE
mdonovanPPE
I installed a plugin called PVCad (https://www.pvcomplete.com/pvcad/) just for testing, and now I'd like to remove it.  But I can't!  I do not see a .bundle in the folder C:\ProgramData\Autodesk\ApplicationPlugins, and when I open the Autodesk App Manager, I see the app but I cannot uninstall because all options are greyed out.  How do I remove this stupid app?
AVCPlugins
The first step is to uninstall programs from the Windows Control Panel. But if you want to delete the folder then
plugins are usually loaded into the user folder "C:\Users\YOURACCOUNT\AppData\Roaming\Autodesk\ApplicationPlugins\PLUGINNAME.bundle" . There is also a folder "C:\Program Files\Autodesk\ApplicationPlugins".
But it's better to look where the plugin dll is loaded from in the list of processes, because through the autoload key in the registry, you can specify the plugin to be loaded from any directory.
Plugins for AutoCAD
A>V>C>
AppStore | Facebook | Twitter | YouTube | Blog
mdonovanPPE
ahh, of course! The control panel works.
