Publishing Color Issue
lbellino4
Message 1 of 22
lbellino4
Hello.
Just noticed this issue today that I haven't seen before. I used the publish command to plot the multiple tabs in my drawing, which I've done many times. I had revisions on some of the sheets which I clouded. But for some reason, on one sheet, the cloud plotted/shown as red (which is correct and what I prefer to see) and on another sheet, it is shown as black. Why is that and how do I fix? Thanks in advance for the help.
All clouds are on the same layer and the layer color is red and I'm working in Autocad 2016.
Replies (21)
Message 21 of 22
lbellino4
No. I tried plotting and publishing to pdf in both drivers as you suggested and it does the same thing. Even when I'm in the drawing file to plot, the cloud color looks correct on each of the pages, until I do a "print preview", then on select pages (same ones as I've shown before), the preview shows the cloud in the black color and not the red. So the preview is correct as to what will print. And not what I want.
Message 22 of 22
lbellino4
Well, I finally got this issue fixed with some comments from Autodesk. Gave them the same sample drawing that is in this post and they did the following commands and it fixed the issue...for now.
Purge, -Purge and Audit.
I've done purges in my drawings, but not the audit. So I definitely will be doing this going forward. Thanks for the help.
