Problem with batch ploting to PDF
I'm using the function batch plot on AutoCad 2010 do generate a single PDF file with several dwg's, the problem is that if i open the pdf with acrobat reader, he cant read the font format, if I open the same pdf on a web browser, it shows up normal, even though on the preview it's normal. Also, the file is very small, about 2mb, and yet it's very slow to navigate trought the pages.
I can use microstation to do the same thing, and using him, the pdf works normally
I have attached one pdf with this issue.
Att,
pendean
Community Legend
Community Legend
You need to set your chosen PDF driver to "capture all fonts" or "convert text to geometry".
I've found the option to convert text to geometry, it works now.
Print > Manage Plotters > DWG to PDF > Custom Properties
Thank you
