Two objects with same insertion point both move when one is selected
MRM4TN
MRM4TN
A co-worked has run across an interesting problem. A client had suggested some settings changes on a project the two of them are working on together. Now, anytime one objected is selected and has the same insertion point as another object, both objects are picked. Meaning, if one is chosen to MOVE, both will move instead of just the one that was selected. Anyone know what this setting is to correct it? Thanks.
imadHabash
can you share those two objects for testing ?
Imad Habash
Todd_Rogers
Are they grouped? If you select it, and look at the properties, what does it say it is? If it says Group, you can use UNGROUP.
Todd Rogers
Civil Administration at Walter P Moore
