AutoCAD Forum
PSLTSCALE's system variables
5 REPLIES 5
252 Views, 5 Replies
The PSLTSCALE's system variable cannot be saved, and changed every time reopen autocad 2024.
5 REPLIES 5
cadffm
in reply to: 2557003216
Are you sure?
Open the same file, the same layout and check psltscale again.
PSLTSCALE Is saved per Layout.
Sebastian
pendean
perhaps you are not aware of #1 in the screenshot below (and maybe even #2?)
Simon_Weel
Maybe it gets changed when acaddoc.lsp is loaded / executed.
in reply to: pendean
OK! got it.It would be better saved in dwt I think.
cadffm
In exist files, you have to do it in each layout ( consider the consequences, so I would never automation it ) .
For new files, based on a template, the .dwt saved as  dwg is what you get. So you are right, this is the place to set up your own predefined layouts.
Sebastian
Forma Design Contest
AutoCAD Beta
