The PSLTSCALE's system variable cannot be saved, and changed every time reopen autocad 2024.
Solved by pendean. Go to Solution.
Are you sure?
Open the same file, the same layout and check psltscale again.
PSLTSCALE Is saved per Layout.
Sebastian
perhaps you are not aware of #1 in the screenshot below (and maybe even #2?)
In exist files, you have to do it in each layout ( consider the consequences, so I would never automation it ) .
For new files, based on a template, the .dwt saved as dwg is what you get. So you are right, this is the place to set up your own predefined layouts.
Sebastian
