AutoCAD Forum
PDF Preset
1 REPLY 1
729 Views, 1 Reply
PDF Preset
How do you add "PDF Presets"?
I publish including a lot of layout tabs but need them to print in grayscale.  I also need them to include all layers and bookmarks.
I have PC3's set-up from previous versions which I use to to publish in grayscale using the "plotter named in page setup" but this won't include layers or bookmarks.
When I modify the preset pc3's importing an existing pc3 the preset dissappears from the PDF Preset dropdown.
Need help.
1 REPLY 1
pendean
Edit the DWF to PDF PC3 file you want to use (PLOTTERMANAGER command, double-click on that PC3 file) and set the layers/bookmark options there http://thatcadgirl.com/did-you-know-about-dwg-to-pdf/ , and for monochrome you need to create pagesetups in a template file and import when needed http://www.ellenfinkelstein.com/acadblog/tutorial-create-a-page-setup-for-plotting/
Forma Design Contest
AutoCAD Beta
