AutoCAD Forum
object missing when i loaded into Revit
8 REPLIES 8
Message 1 of 9
663 Views, 8 Replies
Hi, Friends:
i have a cad 3d file which need to link into Revit,
but i found there is too many object missing.
can you help me?
thx.
8 REPLIES 8
Message 2 of 9
ennujozlagam
hello, here is your file in Revit 2018. thanks
Message 3 of 9
in reply to: ennujozlagam
Dear   :
how can you do that, Can you kindly show to me?
this CAD file is just a part plan of full layout.
Message 4 of 9
ennujozlagam
hello, this is only the objects/drawing in your autocad file?
IN REVIT
1) open your revit file
2) go to 3d view
3) go to insert
4) go to link cad
5)select your file from your folder
thanks
Message 5 of 9
turn out, what i tried is Revit 2012,
any idea how to load in 2012?
anyway , i will accept your solution.
Message 6 of 9
ennujozlagam
hello, i don't have R2012 but it's the same process. thanks
Message 7 of 9
not the same,
object will missing
Message 8 of 9
ennujozlagam
hello, sorry i don't have R2012 but i tried to another PC  with Revit 2010 and it works fine, same process. I attached the file from R2010 and you can open it to R2012. thanks
Message 9 of 9
ennujozlagam
here embedded your autocad file. thanks
AutoCAD Inside the Factory
