Hi, Friends:
i have a cad 3d file which need to link into Revit,
but i found there is too many object missing.
can you help me?
thx.
Solved by ennujozlagam. Go to Solution.
hello, here is your file in Revit 2018. thanks
Dear ennujozlagam :
how can you do that, Can you kindly show to me?
this CAD file is just a part plan of full layout.
hello, this is only the objects/drawing in your autocad file?
IN REVIT
1) open your revit file
2) go to 3d view
3) go to insert
4) go to link cad
5)select your file from your folder
thanks
turn out, what i tried is Revit 2012,
any idea how to load in 2012?
anyway , i will accept your solution.
hello, i don't have R2012 but it's the same process. thanks
hello, sorry i don't have R2012 but i tried to another PC with Revit 2010 and it works fine, same process. I attached the file from R2010 and you can open it to R2012. thanks
here embedded your autocad file. thanks
