No indication of multiply users
Message 1 of 9
Is there an option where I can download that will let me know if someone else is working on the same dwg file? I am using AutoCAD 2017.
Replies (8)
Message 2 of 9
john.vellek
Hi @Anonymous,
AutoCAD drawing files are not meant to be worked on by more than one user at a time. That is why your operating system put lock files in place to prohibit two users from using the same file at once for editing.
Can you describe your environment and the kind of problem you are having or trying to avoid?
John Vellek
Message 3 of 9
The problem that I am having is that when more than one is working on the same dwg file there is no notice that it is being edited by somebody else and would save on top of my work. I have lost many hours by re-creating my work. If there is a way to let me or someone know that the file is being edited by somebody that would be great. I save my dwg files on the file server.
Message 4 of 9
john.vellek
Hi @Anonymous,
What kind of file server are you using?  File locking is handled by the OS and not by AutoCAD.
Are you seeing the problem with Xref files?  The default value for Xloadctl is 2 but you might try setting it to 1 for all your users to see if that helps.
John Vellek
Message 5 of 9
Ed__Jobe
@AnonymousIf you are using a file sharing server like Dropbox, Google Drive or MS OneDrive, then you are going to run into this problem. They can't lock the file for a certain user. Its last one to save wins.
Ed
How to post your code.
Message 6 of 9
My OS is windows 10, if that matter.
Message 7 of 9
john.vellek
HI @Anonymous,
Unfortunately, that does not affect the issue.  If you are not working off a true Windows server then file locking is going to be hit and miss.
John Vellek
Message 8 of 9
john.vellek
Hi @Anonymous,
I am checking back to see if my post or Ed's helped you with your problem. Please mark a post or posts as accepted solutions if they resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
Message 9 of 9
BeKirra
As others suggested, can you tell what the type of your "file server" is?
Before more details are given, you may try to move (not copy) the drawing file from server to your local disk when starting your work.
It obviously is not a good solution at all. But at least you can work without losing your time.
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
