AutoCAD Forum
Mouse wheel button - zoom extents
4 REPLIES 4
tmccar
289 Views, 4 Replies
Occasionally I accidentally double-click my mouse wheel and the drawing goes to "Zoom Extents". Then I have to zoom previous to get back to where I was. Is there a way to avoid this or prevent it happening?
Tags (2)
Labels (2)
4 REPLIES 4
TheCADnoob
in reply to: tmccar
Disabling MBUTTONPAN (set it equal to 0) will stop that, but it sounds like you are using the middle button to pan... it will also stop that.
CADnoob
Kent1Cooper
in reply to: tmccar
Can you get what you want by adjusting the double-click speed in your operating system settings?  That would also affect usage in other programs, of course.
Kent Cooper, AIA
pendean
in reply to: tmccar
@tmccar Your 3rd party mouse driver controls double-click speeds, start there.
If you are not using one, get a different less sensitive cheap mouse to use instead.
tmccar
in reply to: Kent1Cooper
I set the double-click speed to fast and it has definitely helped!
Forma Design Contest
AutoCAD Beta
