Occasionally I accidentally double-click my mouse wheel and the drawing goes to "Zoom Extents". Then I have to zoom previous to get back to where I was. Is there a way to avoid this or prevent it happening?
Solved by Kent1Cooper. Go to Solution.
Disabling MBUTTONPAN (set it equal to 0) will stop that, but it sounds like you are using the middle button to pan... it will also stop that.
CADnoob
Can you get what you want by adjusting the double-click speed in your operating system settings? That would also affect usage in other programs, of course.
